RobotStudio 5.14.02 is available
Dear RobotStudio users,
RobotStudio 5.14.02 has been released and is available for download from the RobotStudio Community (http://www.robotstudio.com/community). RobotStudio is shipped with RobotWare which means that there is one common image for both RobotWare and RobotStudio.
Licensing and Activation
RobotStudio 5.14.02 will remain activated when upgraded from 5.14 or 5.14.01. A new activation key for RobotStudio 5.x is required if upgraded from 5.13.03 or earlier versions or if it is a new installation. Users who do not hold a valid subscription but are interested in using the Premium functionality of RobotStudio should contact their local ABB Robotics sales representative, see http://www.abb.com/contacts/
RobotStudio 5.14.02 will replace an eventual 5.14 or 5.14.01 installation. Previous versions (5.13.xx) can be kept side-by-side of RobotStudio 5.14.02. When the installer detects an existing installation of a previous RobotStudio version the following question is displayed: Setup has detected an older version of RobotStudio on this computer. Would you like to uninstall it?
What's New?
Check the What's New?-document to find out about the news of 5.14.02. http://search.abb.com/library/Download.aspx?DocumentID=WN_RS_51402&LanguageCode=en&DocumentPartId=&Action=Launch
Check the Release Notes RobotStudio 5.14.02-document to find out about which external reported problems that has been corrected since 5.14.01 http://search.abb.com/library/Download.aspx?DocumentID=RN_RS_51402&LanguageCode=en&DocumentPartId=&Action=Launch
Magnus Gustafsson, ABB Robotics magu2011-10-25 11:08:30
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
