CAD models download site
I just tried to get to the CAD models download site through RS Downloads, but I get the msg "Sorry, but the page you requested has been removed from this site.". I desperately need a specific weld gun and someone told me that there is a solutionsbank or something like that where I also get CAD models for most used tools and weld guns.
Lohengrin
Lohengrin
CAD models for robots and other robot related equipment can you find at www.abb.com. Select Robotics (under OUR OFFERINGS) and then Product Selector.
Ok, I did this, but only found CAD models from your products, but not a real library of common used weld guns. Are there any more models available anywhere else that can be used in RS?All the best,
Lohengrin0 -
This is the only ABB library for CAD models. I recommend that you talk to the manufacturer of the gun for a CAD model.
Which weldgun do you need?
Regards,
Jan-Jaap0 -
I need an ARO C-Gun small (C45, 57 kVA). Thanks for all your help! Lohengrin38708,6107407407All the best,
Lohengrin0 -
Sorry, can't help you with that. Contact Aro.Regards,
Jan-Jaap0 -
Thanks, I did that, but havn't let me into their lib yet. Maybe they are already in vacation...
Thanks for your help.
All the best,
Lohengrin0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
