Creating a loop for robtargets and MoveL
Hi <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Did you try with 50000 instructions? Is it not possible to hold so many instructions? You could also put your positions in an array and do your move instruction in a FOR loop.
You could load it from floppy, but if it is an old controller you might get some errors while reading from floppy because of dirt and dust in the drive. If there is enough space on the Ramdisk it is better to load the module from there. Use:
Load
Unload or EraseModule (Unload is only possible for module loaded by Load instruction, EraseModule is only available in newer systems)
Maybe you have to switch of the reference error detection in the parameters otherwise you might get a reference error after Unloading.
Best regards
Marcel
Marcel I am not able to use Load function because I have Robotware 2.0 and this function is only available with Robotware 2.1...I knew that it is possible to run program directly from a computer, the robot reads in advance few lines and executes them.
I have webware sdk and S4Online with Interlink.I don`t have any idea of how I should make this...if you know and can, please help me.Regards,
Alex0 -
HiWhat are the syntax for the instruction EraseModule, do you have a exsample.Best RegardsSteen0
You can find the syntax in the documentation of RobotStudio Help, Rapid Reference, Instructions:
EraseModule "PART_A";
Erase the program module PART_A from the program memory.
Best regardsMarcel0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
