RSO 5.07 does not connect to RS 5.07
I've just upgraded to RS 5.07. I created a simply simulation and sync'd with the VC. When I go to Program / Robot Studio Online F6, RSO starts up but doesn't connect to my VC. Nothing is diplayed in the Robot View or Controller Status windows. RSO Version 5.7.153.0
Best Regards,
Jim Proulx
Hello Jim,
This is a known limitation in RSO 5.07 which will be fixed in RSO 5.08. For now, you will have to open/create a robot view and add the systems manually.
regards,
Johannes
Johannes Weiman
Hi Jim,
To see your VC in RSO 5.07 you have to create the Robot View and add the controller yourself. Do like this:
Select New Robot View on the Start Page.
Give the Robot View a name and press OK.
Right Click on the Controllers icon in the Robot View and select Add Controller.
Now should you see the VirtualController.
Select the controller and press OK.Best regards,
Hello Johannes and Anders,
Thanks for the information. I am now able to connect.
Jim
[QUOTE=Johannes Weiman]Hello Jim,
regards,
Johannes
[/QUOTE]Actually, this has also been fixed in 5.07.01.
Regards,
Johan.
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
