RS6.03 freezes creating a system
I would like to test the External Axis Wizard, and I started following the Henrik Belrin tutorial from youtube.
https://www.youtube.com/watch?v=s1Vk-xUDGy4
When I try to create a system from the current offline desing, the RS freezes. I tried with the 32 and 64 bit versions. Even with different Robotwares: 6.03.02, 6.02.01,...
It's freezing all the time in this step, (sorry for the spanish version of the software).
Looks like the RS is not able to create a system from the current offline design even though there is no a track in the design. I've just tried it dropping an IRB6400 in the Station.
Could anybody help over here?
/Daniel
/Daniel
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Hello
Are you selecting any options in the previous steps?
Have you tried to reinstall studio?
/Pavel0 -
Same case with me. Tried creating system from layout and it freezes.0
Hello
Please try it with RS6.04 and report if it still fails.
/Pavel0 -
Pavel Riabichev said:Hello
/Pavel
I'm actually working with RS6.04Un saludo, kind regards,
Daniel Aguilar
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
