Robot system cannot boot after installing a product
rzhao
Dear all,
I tried to update the Smart Gripper(SG) of YuMi with Installation Manager in RobotStudio. I added the SG V3.4 but I forget to remove the original version V3.3. Then I cannot start the robot anymore... The robot gives an error on the FlexPendant and then reboot again and again. I attached the error message and the configuration in the Installation Manager.
I would greatly appreciate any help!
Ran
Ran
I guess there is a conflict between the two versions of Smart rGipper. The problem is that I don't have access to the controller now so I can't do any change...0
Hello
Unable to see your error.
You can uninstall RW add-in from the Add-ins tab, in RobotStudio.
/Pavel0 -
Pavel Riabichev said:Hello
/Pavel
bests,
Ran0 -
I have gotten the same problem as rzhao. I installed two versions of the smartgripper software side-by-side and now the controller is stuck in an endless reboot loop, i.e. I am unable to contact the controller and correct the error. Rzhao mentioned he managed get into the boot application. Is there a way to force boot application start in this situation? I would like to avoid removing the controller hdd if possible.
/Mathias
It seems to be possible to change active system for a multi-system controller. We managed to change using RobotStudio. It would be nice to know the proper procedure though...
Hi, I have the exact problem as you.
Would you be able to tell me how you used boot application exactly? I tried to use it in RS, but the message shows that this operation is not allowed in the current operation mode.
Many thanks!0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
