Visualize World Zones
Thils would be very helpful, +10
+10
+10
+1.
One other thing, when using "WZDOSet" in a RobotStudio station it seems like the output is not beeing updated when the robot is entering/leaving the zone.
It's updated once during a warmstart but after warmstart is completed it's freezed.
/David0 -
+10
A workaround I use when I create a wz box is to set wobj0 to UCS and click in the graphics (sometimes I create a box) where you want your corners. The UCS coordinates are shown in bottom right corner of RobotStudio.0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
