Offset workobject
Whats the easiest way to offset the x,y,z of a work object?
found the solution --> workobject.trans.x = X;0
Is it a permanent offset or temporary? Most of the time, in the case of temporary, like vision guidance, I would apply the offset to the Oframe, not the UFrame.Lee Justice1
How to use that temporary workobject... what is its syntax?0
SriHarsha2015 said:How to use that temporary workobject... what is its syntax?
OR
workobject.oframe.trans := [X,Y,Z];
so this won't permanently change the work object data?0
Rickytre91 said:so this won't permanently change the work object data?0
These solutions WILL permanently offset the workobject as a WHOLE. If you want to use a temporary offset, then assign the permanent wobj values to another variable workobject. Example:
WobjTemp:=WobjPermanent;
WobjTemp.oframe.trans.z:=100; ! or whatever you need to changeLee Justice0 -
lemster68 said:These solutions WILL permanently offset the workobject as a WHOLE. If you want to use a temporary offset, then assign the permanent wobj values to another variable workobject. Example:
WobjTemp.oframe.trans.z:=100; ! or whatever you need to change1
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 11 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
