RobotStudio event
Virtual controller can't execute TriggL or MoveLDO instructions
Luxrobotic
Luxrobotic ✭✭
edited September 2018 in RobotStudio
Hi everybody,
I have a station with an IRB2400L that work for several years. Now my customer wants to replace this od IRB2400L by a new IRB1600.
The original program of the IRB2400L use a lot of TriggL an MoveLDO instructions :
I've installed the IRB1600 in my station, and now I'm able to execute the current IRB2400L program. Excepted for TriggL and MoveLDO instructions.
When I make a simulation, I get this error message :
All these routines are working well in the IRB2400L simulation.
When I replace the TriggL instructions by simple MoveL, it works.
Any idea?
Thanks in advance.
Raymond Cornet
Luxrobotic
Regards
Cornet Raymond
Manager
LUXROBOTIC programming Sàrl
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
PC HP ZBook 17 G3
intel Core i7 6700HQ 2.59 GHz
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M
  • lemster68
    Does the new robot have the fixed position events option?
    Lee Justice
  • Luxrobotic
    Hi lemster68,
    I cheched in the controller option, but I don't find anything similar.
    Where is this option located?
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    In the pendant, or virtual, system info, system properties, options.  In a backup, backinfo folder, backinfo.txt.
    Lee Justice
  • Luxrobotic
    Luxrobotic ✭✭
    here are the bakinfo.txt contents :
    # IRB1600
    >>SYSTEM_ID:
    VIRTUAL_USE
    >>PRODUCTS_ID:
    RobotWare Version: 6.07.00.00
      RobotWare Base
      French
      687-1 Advanced Robot Motion
      988-1 RW Add-In Prepared
      608-1 World Zones
      611-1 Path Recovery
      613-1 Collision Detection
      612-1 Path Offset
      885-1 SoftMove
      Drive System IRB 120/140/260/360/910SC/1200/1400/1520/1600/1660ID
      ADU-790A in position X3
      ADU-790A in position Y3
      ADU-790A in position Z3
      Axis Calibration
      IRB 1600-10/1.2
    >>HOME:
    All public files and directories
    >>SYSPAR:
    SYS.cfg
    PROC.cfg
    MMC.cfg
    EIO.cfg
    SIO.cfg
    MOC.cfg
    # IRB2400L
    >>SYSTEM_ID:
    VIRTUAL_USE
    >>PRODUCTS_ID:
    RobotWare Version: 5.11.3015.03
      RW Control module key
      RobotWare OS and English
      644-1 French
      602-1 Advanced Shape Tuning
      603-1 Absolute Accuracy
      604-1 MultiMove Coordinated
      608-1 World Zones
      RW Drive module 1 key
      ABB standard manipulator
      IRB 2400 Type A
      2400L Type A
      Add axes IRB/drive module 140/1400
      RC1 No add drive
    >>ROBOT_TYPE:
    2400L Type A
    >>HOME:
    >>SYSPAR:
    SYS.cfg
    PROC.cfg
    EIO.cfg
    SIO.cfg
    MOC.cfg
    MMC.cfg
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    So, since you have what appears to be right now, a virtual controller, modify that system to include the option and see if it makes your problem go away.  But the real robot will have to have that option purchased if this is the fix.
    Lee Justice
  • Luxrobotic
    Could you please show me which option to select in the Controller options ?
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    lemster68 ✭✭✭
    Try motion events. No, I see that is world zones...still looking.
    Lee Justice
  • Luxrobotic
    Motion envents is already activated (Only World zones available in this section)
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    Which version of RS are you using?  Mine does not look quite the same.
    Lee Justice
  • Luxrobotic
    6.07.01
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    Should be "fixed position events", but I am not finding it in the installation manager.
    Lee Justice
  • Luxrobotic
    after some research, I found this topic :
    Start system builder from menu controller and select your system and press modify and then press next until you get to the "Modify Options" dialog and check option 609-1.
    I checked in the options available in the system, but didn't found option 609-1.
    Even if I try to build the new system with differnet RW versions.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • lemster68
    I could not find it either, I also tried an older version of rs.
    Lee Justice
  • Luxrobotic
    what is really strange, is that when I compare both of my systems, I don't find this option in any of them :
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Jorge
    AS said the message error that you show in the first post, check other error that logged at the same time.
    Jorge Turiel
  • Luxrobotic
    HI Jorge,
    unfortunately there are no other messages.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Jorge
    Hi, can you upload a backup?
    Jorge Turiel
  • sturner
    Fixed Position Events are included in standard Robotware 5 and 6.
    You will need to add these instructions in the template manager in order to see them in the station, I.E. (synchronize to station)
  • Luxrobotic
    HI,
    sorry for the late reply.
    Thank you sturner for reminding me what to do !!
    I did for some instructions, but I forgot for some other, that's why it didn't work.
    Thanks to all
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Luxrobotic
    HI,
    I did it for some instructions, but I forgot for some other, that's why it didn't work.
    Thanks to all
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Luxrobotic
    HI,
    I did for some instructions, but I forgot for some other, that's why id didn't work.
    Thanks to all
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
