RobotStudio event
testDI function
Hello all I would like to know what is the real difference between these two lines
IF DI_mySignal THEN
and  the same using IF TesetDI(DI_mySignal) THEN
Both are working but what is the real differenece?
Thank you
  • DenisFR
    DenisFR ✭✭✭
    You can write it like this too:
    IF DI_mysignal=1 THEN
    or
    IF DI_mysignal=high THEN
    But if you define badly DI_mysignal nothing happens in syntax check.
    TestDI have a signaldi parameter, so it have to be defined as this.
    And TestDI handles errors:
    Error handling
    The following recoverable errors are generated and can be handled in an error handler. The system variable ERRNO will be set to:
    Name
    Cause of error
    ERR_NO_ALIASIO_DEF
    The signal variable is a variable declared in RAPID. It has not been connected to an I/O signal defined in the I/O configuration with instruction AliasIO.
    ERR_NORUNUNIT
    There is no contact with the I/O device.
    ERR_SIG_NOT_VALID
    The I/O signal cannot be accessed. The reasons can be that the I/O device is not running or an error in the configuration (only valid for ICI field bus).
  • Micky
    Micky ✭✭✭
    the difference is that function "TESTDI" returns a boolean value (True or False) instead of "high" and "low".
    I think there is no additional error check inside this function.
    The function will probably look like this:
    FUNC bool TESTDI(VAR signaldi Signal)<br>  RETURN Signal = high;<br>ERROR<br>  RAISE;<br>ENDFUNC<br>
    I think if you use an "IF" statement in your code, it will be faster than calling the TESTDI function.
    BR
    Micky
  • I found this code in an older mediapool for S4 generation controllers:
     ! Test Digital Input
     FUNC bool TestDI(VAR signaldi Signal)
      IF Signal = 1 THEN
       RETURN TRUE;
      ELSE
       RETURN FALSE;
      ENDIF
     ENDFUNC
    Lee Justice
  • DenisFR
    DenisFR ✭✭✭
    I take the text from documentation.
  • I see, Denis.  Makes me curious if the error is generated in the routine that calls the function or if the function has its error handler which RAISES the error.
    Lee Justice
