Command "Convert toMove Circular" not available
Luxrobotic
Hi everybody,
I have created a path with MoveL instructions and I need to convert some of these instruction to MoveC.
But the command "Convert toMove Circular" not available, when I select 2 MoveL instructions.
Do you have any idea?
Regards
Cornet Raymond
Manager
LUXROBOTIC programming Sàrl
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
PC HP ZBook 17 G3
intel Core i7 6700HQ 2.59 GHz
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
First U need to select two MoveJ/L instructions and Click Modify, then "Convert to Move Circular" will be shown.
Refer to the picture below.
Hi innebandy,thanks for your reply.That's what I did. As usual, by selecting 2 MoveL and also with a MoveJ and a MoveL.But no way.Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M0 -
Hi,any idea ????Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
One condition is that both instructions must use the same wobj and tooldata.
If that is not the problem I'm not sure what it can be. Can you upload the station?
Regards,
Johannes
Johannes Weiman
Hi Johannes,I use the same wobj and the same tooldata.One strange thing is that when I created my positions, I checked the option to insert them into an existing path. I did first only one half of my path, when the Move instructions were created, I had no problem to convert some in MoveC. But when I created the second part of my path in the same way then before the problem occured, the command wasn't available anymore.How can I send you the P&G?Regards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
The problem is that the existing MoveL instructions have a different process ("Depart") than MoveC ("Move").
For convert to circular to work, there must exist a circular instruction in the same process as the selected instructions.
You can fix this in "Edit Instruction Templates".
Regards,
Johannes
Johannes Weiman
HI Johannes,I expected something like this.I've changed the process name "Depart" to "Move" for all the instruction template.Now it's ok.Thanks a lotRegards
Cornet Raymond
Manager
+352 621 354 570
PC HP ZBook 17 G3
RAM 16GB
HDD 1TB
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
