Smart component
Moises
Hi! I use robotstudio 6.8.1. I have a proyect with smarts components. I can not run it in rapid editor. I search in forums but i dont see a good response. Samebody can help!
Thanks!
Thanks!
Hi Moises, it's a bit hard to follow what you try to do.
You've to contribute with more information.
The RAPID editor is executed on the robot controller meanwhile smart components are part of the RobotStudio station.
The more concrete your question is, the easier it is to help!0 -
Escribe tu comentario
Thanks for help! In "simulacion "any problem. ALL run.0 -
I guess you probably missed a station logic which is a sort of virtual wiring between the Smart Components and the Virtual Controller.
No. I think that is coordination problem between station and controler.0
Moises, please try to describe step by step what you want to achieve.
Smart components can be found in Simulation -> Station Logic.
Maybe this video can be of help: https://www.youtube.com/watch?v=gH7_pLTOO2U0 -
Smart Components only run in Simulation mode not via the virtual pendant.
Ok. Thanks you very much!0
Yes, many (but not all) Smart Component require a running simulation to function properly.
If you don't want RAPID execution to start automatically when the simulation starts, you can uncheck that option in Simulation Setup. Then while the simulation is running, you can start and stop execution from the RAPID tab or the Virtual FlexPendant.
Johannes Weiman
Thanks you for all! I learn a lot with the forum.0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
