Communication between PC and ABB IRC5 Compact RobotController
You may wish to check the Application manual for Controller software IRC5, as well as the Technical reference manual RAPID Instructions, Functions and Data types for your request. Open, Write & other Write-based instructions are hints to pursue.
1 -
You need to order the option PC Interface 616-1. This will provide Ethernet TCP/IP support via the ethernet ports
j_proulx said:You need to order the option PC Interface 616-1. This will provide Ethernet TCP/IP support via the ethernet ports
PC Interface is for communication via the Ethernet ports. The service port can be used to communicate via ethernet tcp/ip for Robot Studio but don't hook it up to an area network. It is a master that issues IP addresses to what ever is connected and can crash a network. You may be able to use SB if you have one of the file transfer protocol options like FTP server. See chapter on Communication in the attached manual. For Serial Communication RS232 you need to add hardware option 970-1.1
j_proulx said:For Serial Communication RS232 you need to add hardware option 970-1.
If so, if there is any simple way for me to test this connection by sending maybe a bit/ byte of data from PC to robotcontroller and vice versa in order to verify their communication?
Yes the lower connector is the serial port (was standard on the generation 1 compact controller).
I have no experience with setting up serial communications, the attached from the manual may help.
1 -
I mean how to give it an input "6" in order for it to continue the routine? Thanks in advanced.
Robotcontroller PC
Service port <----------------------> Ethernet port
Serial port (COM1) <-------------------> usb port
Then I tried sending "6" in both oct, hex and bin format through serial port terminal installed on my PC to the robotcontroller, but there is no any response as I reading from the robotstudio. Did I doing the right steps or how should I do to test it?
Did you use the Open command initialize communication?
Open is used to open a file or serial channel for reading or writing.
The Technical reference manual RAPID instructions has examples...
SomeTekk said:Did you use the Open command initialize communication?
The comment says wait for the control character ack (presumably acknowledge).
Try taking this line out and put in a waitime of say 0.1 sec.
On the PC end have other methods of interfacing been tried?
I was able to get a freeware terminal software to work with Socket Communication. The software at the link below does interface over RS-232.
https://www.hw-group.com/software/hercules-setup-utility0 -
SomeTekk said:On the PC end have other methods of interfacing been tried?
The code I used to test is as below:
MODULE MainModule
PROC main()
VAR iodev deRS232;
Open "COM4:", deRS232\Bin;
WriteStrBin deRS232, "U";
Close deRS232;
ENDMODULE
Below is the data retrieved from the robotstudio which is connected to my IRC5 compact robotcontroller
Regrettably I cannot duplicate your hardware setup at the moment. I will see what can be done to change that.
For now, have you tried using the code retrieved from the ABB Robot Communication and IO control manual with the Hercules server software?
The Hercules software will allow a '6' to be sent.
1 -
SomeTekk said:Regrettably I cannot duplicate your hardware setup at the moment. I will see what can be done to change that.
Still, your wishes are not easy, it’s so easy not to do it.I know that this problem can be solved with the help https://www.serial-over-ethernet.com/ software. Connect your box to a PC that has access to a network or the Internet. And the second PC on which you want to remotely access your machine. With the help of the program you get client and server communication and you can control Robotic Arm.Post edited by Spencerkrit78 on0
Albert_Tie said:I have a Robotic Arm ABB 120 and a ABB IRC5 Compact Controller. I am able to communicate to IRC5 Compact robotcontroller through Service Port on the controller. However, I want to explore more effective communication method between my PC and IRC5 Compact controller as to reduce the latency. Is there any way to connect and do the file/data transfer from PC DIRECTLY to robot controller through the USB port on the robot controller? Is the USB port on the IRC5 Compact controller is intended for the use of data communication between PC with the robotcontroller? In addition, does anyone knows and can help me with the RAPID programming for the USB-Serial configuration (PC(usb)<--> IRC5 Compact(Rs 232))? I welcome any sort of comment and help. Thanks in advanced!
i have successfully done one project with rs232 communication, work perfect. But only variables from PLC in string format.I would now upload a text file in real time.Have you discovered anything new in the meantime?
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
