Cant change WAN IP through Propierties
I'm trying to change WAN IP through RobotStudio 2019 and it cames with an error. I have to do like in the old days. Boot Start and change with the Teach Pendant...
https://youtu.be/uD0neDYJvjU
Un saludokind regards,
Daniel Aguilar
Automation Engineering
  • SOLVED. Subnet 130 cannot be used in WAN port. It's reserved for the controller.
    Daniel Aguilar
