Passing a mecunit as a parameter to a PROC
I have a few robots with external servos on the gripper and I want to write a PROC that all the robots can use, so I'm trying to pass a Mecunit as a parameter into a routine. I'm presented with a fault saying that a mecunit is not a value. Is there a clean way of passing a mecunit?
How about using a switch, then use function Present?Lee Justice0
I thought about that but I some robots have one external axis and some have 4 so I want to write a routine that I just feed the parameters and no matter how many axis it will be the same code.0
The switch is optional, you a.) don't pass any at all, b.) pass one or more or, c.) use them all if appropriate.Lee Justice0
IF Present(swMecUnit1) THEN
ActUnit MecUnit1;
Do whatever;
either another IF or ELSEIF
blah blah
ENDIFLee Justice0 -
Is there a way to read which mechanical unit is configured on the robot?0
Maybe, but I am almost done here for today. I can look tomorrow if you have not found out.Lee Justice0
I think I got it. I had to put a VAR in front of the data type
PROC EOATServo(var mecunit Servo,robtarget pTarget,num Speed)
Yup that's what it was0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
