Storing a group output value to a variable
Hello All,
Am using IRB6700 robot for pick and place Palletization application. i recive the count values from siemens PLC using profinet. Assigned Group Input and Group Output to receive decimal values from PLC to robot. But i do nit know how to store the decimal values of Group Output in a variable.
Any sample code would be helpful. Or any other method also appreciated.
Best Answers
Rapid function GInput to read the value of a group input signal, and GOput to read a group output signal.
5 -
Code below, no data declarations though.
nMyNumber:=gi_myGroupInput;
SetGO go_MyGroupOutput,nMyNumber;5
Thanks all.
Also i would like to know is there any way to send and receive integer from PLC via Profinet instead of using Group inputs and outputs.0 -
Set it up as an analog signal. Refer to system parameter manual, inputs/outputs.Lee Justice0
Hello all.
I have got an error when executing the following Instruction:
Var Signalgi PINFEED_CNT;
var num count;
count:=PINFEED_CNT;
Am getting Alias IO instruction error.0 -
The group input needs to be setup in the EIO configuration file not in RAPID.
Are you using RobotStudio to do your programing or via the teach pendant?
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
