Omnicore FlexPendant (virtual)
sturner
OmniCore Virtual FlexPendant fails to connect to virtual controller error
Error message
Uninstalled both RW7 and RS and reinstalled, reset RS options to default and still does not work... Hmmm!
I was able to successfully create a RW7 Virtual w/ pendant. I have attached pack&go. verify your Robot User Interaction Application options are checked.0
Hi, problem fixed with RS2019.5.3 Beta
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
