RobotStudio 2019.5.3 install issues?
TeHr
I'm trying to download RobotStudio 2019.5.3 on my Carnegie Mellon University laptop. When I go to download it, I get the message, "Error reading setup initialization file". Any ideas of why this is happening & what steps I would need to take to fix it? We have a University license.
Please explain in detail what you are doing.
For example, after you download the zip-file, do you unpack it or start from the archive directly?
Thanks.—Maxim RiabichevPC Software Support Engineer0 -
After downloading the file from ABB's website, I unzip the file, click setup.exe, then almost immediately the message, 'Error reading setup initialization file' pops up. I have even moved the setup.exe file onto my desktop, but it still does the same thing. I'm thinking there is something in my computer that is causing the problem.0
Does your windows account have permissions to install software?—Maxim RiabichevPC Software Support Engineer0
Yes. I am an administrator.0
Does this apply? http://buildsoftsupport.com/knowledge-base/error-reading-setup-initialization-file/
Straight from Google—Maxim RiabichevPC Software Support Engineer0 -
Actually, I figured out how to download RobotStudio. Sorry, I'm having issues with another robot software. Thanks for your help.0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 243 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
