RobotStudio event
Event manager. Set DO to 1 when collision
I have made an event that set a DO=1 when collision is detected.     <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The collistion_set is workin fine and i can simulate my DO in the     I/O simulation window.
The event is made with following settings:
Activation = On
Trigger Type = Collision
Trigger Name = CollisionSet_2    (Works when running simulation
Trigger Parameter = Started
Action Type = Change I/O
Action System = System1  (Only System installed)
Action Name = DO_Soeg (Can be simulated in I/O window)
Action Parameter =1
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Forgot to write that i use rs 5.07.1834.1023
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi Klaus,
    There is unfortunately a known problem with events trigged by collisions in RS 5.07.1834.1023. This problem will be solved in RobotStudio 5.08.
    ABB Robotics
  • When does it released
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • RS 5.08 will be released quarter one next year.
    ABB Robotics
