SmartComponentCodeBehind.OnInitialize Method
DenisFR
Could someone explain me this methods?
I cannot get it working. Never called.0
Up0
Hello Denis,
Have you see this reference: http://developercenter.robotstudio.com/blobproxy/devcenter/RobotStudio/html/34d33a0a-01ab-465d-93ac-cab319cac46e.htm
I can't explain that method, but perhaps you'd want to use the OnLoad method instead?Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 -
Hello @Maxim Riabichev ,Thanks a lot.No I haven't see that. Should be added to 'See Also' section.Could someone review my codes in https://github.com/DenisFR all RS repos.So they could be added to example.0
Hello Denis,
In regards to SmartComponent examples, have you seen this post: https://forums.robotstudio.com/discussion/12091/finding-example-code-for-building-smartcomponents
I will have a look at your code when I get some spare time
Hello,I didn't know this software.I'll have a look at this ASAP.ThanksMaybe I've found some guidance for this topic:
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
