Download Virtual SmartGripper
ABB_YuMiGuideABB_YuMiGuide ABB Cobot Solution Centre admin
edited May 18 in YuMi
Dear All,
You can now download the Virtual SmartGripper. Some details are explained below.
  • What is the Virtual SmartGripper?
               -> SmartComponent for RobotStudio
               -> Firmware/ Graphical simulator for ABB's SmartGripper
  • What can the Virtual SmartGripper do?
               -> Manually move the gripper fingers
               -> Manually attach/ detach objects to the servo fingers/ to the vacuum cups
               -> Simulating SmartGripper's RAPID functionality completely
               -> Calibrating the finger servos
               -> Attaching/ detaching objects automatically during simulation to the servo fingers/ to the vacuum cups
  • How can it be installed?
               -> Until it will we officially released, you can download it from the attached zip folder.
              -> Unpack this folder, inside there is a word document "VirtualSmartGripper_Installation.docx"
               -> Follow the instructions there, there is also an example which you can use directly.
If you have any additional questions/ feedback, please post them here.
Regards,
ABB_YuMiGuide
Post edited by ABB_YuMiGuide on
  • FlorianKnechtFlorianKnecht Germany mod
    edited May 18
    Dear All,
    After more tests depending on different situatiuons, I updated the Virtual SmartGripper project containing some bug fixes.
    I also built the most used SmartGripper Versions within this update, they are all in the folder uploaded from ABB_YumiGuide. Thanks for updating it in the main post.
    This update fixes the known issues:
    • Loading a Station containing multiple Virtual SmartGrippers didn't work in each case.
    • Loading multiple Virtual SmartGrippers into a Station didn't work in each case.
    • Disconnect Station Logic now just disconnects the SmartGripper from the controller (before, all connections to the SmartGripper were deleted)
    Regards,
    Florian
    Post edited by FlorianKnecht on
Sign In or Register to comment.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
In this Discussion
