Error
joaoeq
I have this error when trying to create a new workstation at robotstudio, could someone help me?
Last installed RobotStudio 2020.1 version
Error message:
Exception: Unable to load DLL 'RobotStudio.Native.Graphics.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Hello MaximProblem solved, I uninstalled the program and removed all registrations, reinstalled and it worked.Thank's for your time
Best Regards
Joao0
My suggestion would be to uninstall and reinstall RobotStudio.
Make sure to unzip the archive before you launch setup.exe too.—Maxim RiabichevPC Software Support Engineer0 -
Hi MaximThanks for answering.Well, I already did that and it had no effect, the same error continues.0
What version of Windows are you using?—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
