Interesting bug with shared modules in RW6.08
I have been trying to figure out why my shared module programs often get the error:
40330 Task: TASKSHARED. Module (line/column): SysGlobalFunc 67 5 . There is an error with symbol: ESCAPEMENT.
I have many other programs which which use shared modules (go check them out they are super useful) and this problem stumped me for a while.
Essentially, my system has 3 Tasks and is a multi-task system:
T_ROB1 (TASK1)
Escapement (TASK2)
Background (TASK3)
And I have two shared modules SysGlobalFunc And SysMessages. Basically, they exist to serve messages and other common data to other tasks.
I would get the error 40330 when trying to install "SysGlobalFunc". I could get rid of the error by commenting out like 67. But that leaves me without the variable which I commented out.
THAT FIXED IT!!
Apparently, this bug is that you cannot have a string with the same name as a TASK. I couldn't find any documentation in the Kernel on reserved words or having a variable with the same name as a other portion of the program.
T_ROB1 (TASK1)
Escapement (TASK2)
Background (TASK3)
MODULE SysGlobalFunc(SYSMODULE)
!CONST string ESCAPEMENT:="ESCAPEMENT";
Seems relatively benign, I couldn't figure it out. So I uncommented out other variables, but no issue. So I changed the offending variable to:MODULE SysGlobalFunc(SYSMODULE) ... CONST string NOT_ESCAPEMENT:="ESCAPEMENT";
THAT FIXED IT!!
Edit: As lemster68 pointed out in a post below, this is not a bug.Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 -
This is neither a bug nor does it have to do with built in shared modules. It is simply the "rules" of the rapid language. You may not have a module name the same as a data declaration name, or a routine named the same as a module name. The symbols are then ambiguous, does not compute. The same will apply for the name of a task.Lee Justice0
Thanks for clearing that up @lemster68! It makes sense.
Do you know if these "rules" are written down somewhere, or is this something one has to realize because "it makes sense"?—Maxim RiabichevPC Software Support Engineer0 -
You are welcome Maxim. The rapid kernel manual gives some guidance, but I think that in this specific case it is not quite so clear. Years of experience help, part of which is making mistakes like that or near enough.Lee Justice0
I should also add that the Rapid Overview is useful, as well.Lee Justice0
I still believe it is a bug, because even though I agree that this should be in the rules. The Rapid Kernel manual is silent on the issue.
And as a point, I can have the variable anywhere in the program with the same name of the task. No errors occur. But as soon as I have it in a shared module, I get the error.0 -
I tested briefly in RS, it did not like it at all when I made a string variable named the same as the module name. The same when I made a routine with same name as the module. Did not go so far as to create another task, though, so I will not argue that. Like I said, just a brief test.Lee Justice0
I tried it on my real controller and having a CONT string Your_task_name produced no errors. I haven't tried making a string the same name as a module however.0
barrettsmithbb said:I still believe it is a bug, because even though I agree that this should be in the rules. The Rapid Kernel manual is silent on the issue.
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
