RAPID Syntax Error
innebandy
I'd like to use a FOR loop to reduce the number of instructions. However, a syntax error occurs when I coded a routine as below. Can anyone help implement it?
THX.
PROC rTruncate()
THX.
PERS jointtarget jpos0:=[[8.64979E-6,2.03798E-6,-6.139E-6,2.2349E-5,20,-2.23871E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos1:=[[8.64979E-6,9.76204E-6,-2.88898E-7,-180,-20,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos2:=[[8.64979E-6,93.0963,-180,7.98897E-6,106.904,9.36989E-7],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos3:=[[8.64677E-6,93.0963,-180,-180,-106.904,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos4:=[[-180,-87.5354,-27.4211,-180,85.0435,-1.1935E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos5:=[[-180,-87.5354,-27.4211,8.57699E-6,-85.0435,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos6:=[[-180,-23.0743,-152.579,-180,24.3467,-2.69069E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PERS jointtarget jpos7:=[[-180,-23.0743,-152.579,2.2267E-5,-24.3467,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
FOR i FROM 0 TO 7 DO
jpos{i}.robax.rax_1:=Trunc(jpos{i}.robax.rax_1\dec:=2);
jpos{i}.robax.rax_2:=Trunc(jpos{i}.robax.rax_2\dec:=2);
jpos{i}.robax.rax_3:=Trunc(jpos{i}.robax.rax_3\dec:=2);
jpos{i}.robax.rax_4:=Trunc(jpos{i}.robax.rax_4\dec:=2);
jpos{i}.robax.rax_5:=Trunc(jpos{i}.robax.rax_5\dec:=2);
jpos{i}.robax.rax_6:=Trunc(jpos{i}.robax.rax_6\dec:=2);
ENDFOR
ENDFOR
Try this.
PERS jointtarget jpos{8}:=[[[0,2.03798E-6,-6.139E-6,2.2349E-5,20,-2.23871E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]],[[8.64979E-6,93.09,-2.88898E-7,-180,-20,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]], [[8.64979E-6,93.0963,-180,7.98897E-6,106.904,9.36989E-7],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]],[[8.64677E-6,93.0963,-180,-180,-106.904,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]], [[-180,-87.5354,-27.4211,-180,-85.04,-1.1935E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]],[[-180,-87.5354,-27.4211,8.57699E-6,-85.0435,0],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]], [[-180,-23.0743,-152.579,-180,24.3467,-2.69069E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]],[[-180,-23.0743,-152.579,2.2267E-5,-24.3467,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]]; PERS jointtarget jpos0:=[[8.64979E-6,2.03798E-6,-6.139E-6,2.2349E-5,20,-2.23871E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos1:=[[8.64979E-6,9.76204E-6,-2.88898E-7,-180,-20,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos2:=[[8.64979E-6,93.0963,-180,7.98897E-6,106.904,9.36989E-7],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos3:=[[8.64677E-6,93.0963,-180,-180,-106.904,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos4:=[[-180,-87.5354,-27.4211,-180,85.0435,-1.1935E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos5:=[[-180,-87.5354,-27.4211,8.57699E-6,-85.0435,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos6:=[[-180,-23.0743,-152.579,-180,24.3467,-2.69069E-5],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PERS jointtarget jpos7:=[[-180,-23.0743,-152.579,2.2267E-5,-24.3467,180],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]]; PROC rTruncate() FOR i FROM 0 TO 7 DO jpos{1}.robax.rax_1:=Trunc(jpos1.robax.rax_1\dec:=2); jpos{2}.robax.rax_2:=Trunc(jpos2.robax.rax_2\dec:=2); jpos{3}.robax.rax_3:=Trunc(jpos3.robax.rax_3\dec:=2); jpos{4}.robax.rax_4:=Trunc(jpos4.robax.rax_4\dec:=2); jpos{5}.robax.rax_5:=Trunc(jpos5.robax.rax_5\dec:=2); jpos{6}.robax.rax_6:=Trunc(jpos6.robax.rax_6\dec:=2); !... ENDFOR ENDPROC
I tried a similar method as you, but failed. I Probably missed something.
Thanks a lot.
Pleasure.0
Hello,Arrays in RAPID start with index 1 and not with index 0.But since you don't use an array you have to use the instructions "GetDataVal" and "SetDataVal" to access the content of variables by name.Here is an example:PROC Example()FOR i FROM 0 TO 7 DOTruncJointTarget "jpos"+Valtostr(i);ENDFORendprocPROC TruncJointTarget(string JointName)VAR jointtarget jtTemp;GetDataVal JointName,jtTemp;jtTemp.robax.rax_1:=Trunc(jtTemp.robax.rax_1\dec:=2);jtTemp.robax.rax_2:=Trunc(jtTemp.robax.rax_2\dec:=2);jtTemp.robax.rax_3:=Trunc(jtTemp.robax.rax_3\dec:=2);jtTemp.robax.rax_4:=Trunc(jtTemp.robax.rax_4\dec:=2);jtTemp.robax.rax_5:=Trunc(jtTemp.robax.rax_5\dec:=2);jtTemp.robax.rax_6:=Trunc(jtTemp.robax.rax_6\dec:=2);SetDataVal JointName,jtTemp;ENDPROC0
Hello Micky,
I fixed the problem using an array and your idea is also a good alternative. Thanks.
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
