Is it possible to iterate through all tasks without any information of the tasks?
I am trying to create a function where I check if all tasks are running or not, but I cant find a way to iterate through all tasks.
I am thinking something like this
I'd rather not use the ReadCfgData to analyze the systemparameters if not absolutely neccecary.
<div> FOR taskNo FROM 1 TO 20 DO</div><div> IF NOT TaskIsExecuting(taskNo) RETURN FALSE;<br></div><div> ENDFOR</div>but the TaskIsExecuting-function does not take a number as input.
//Markus Näslund
TaskIsExecuting("T_Rob" + NumToStr(TaskNo,0))Lee Justice0
It is suggested to try an array with the task names.
CONST string stTaskNames {5}:= ["T_ROB1", ... T_TaskX"];
FOR index FROM 1 to dim(stTaskNames,1) DO
IF NOT TaskIsExecuting(stTaskNames {index}) RETURN FALSE
Thank for your suggestions, but unfortunately I don't know anything about the present tasks at "compile-time" so I cannot use the array-solution.
Also, I cannot take for granted that the tasks are named in a certain way so to build the tasknames is not an option.
//Markus Näslund0 -
It sounds then like you are going to have to go with ReadCfgData.Lee Justice0
I agree with lemester68 to use the ReaedCfgData, but it is not possible to search directly for the names of the tasks, because you could only search for the value of a string parameter in the configuration data.
The following code searches only for all normal tasks in the system:LOCAL PROC GetTaskName() VAR num nListIndex; VAR string stTaskName; !read all normal task names from sys.cfg WHILE nListIndex<>END_OF_LIST DO ReadCfgData "/SYS/CAB_TASKS/Type/NORMAL","Name",stTaskName\ListNo:=nListIndex; TPWrite "Task name: "+stTaskName; ENDWHILE ENDPROC
If you want to search for all task types you have to add a search for the static and semi-static tasks.
Thanks for your suggestion. I have already considered this but I was looking for an "easier" way. Something like GetTaskName 1; would give me the name of task 1.//Markus Näslund0
Hi Markus,
Did you ever happen across a convenient way of doing this?
I ended up writing a module (below) to discover the tasks and store some info about them,
but was also looking for a more simple way to get the data%%% VERSION:1.0 LANGUAGE:ENGLISH %%% MODULE Forge_Task(SYSMODULE) !--------------------------------------------------------------------------------------------------! ! Description: Example Description ! ! ! ! | Revision | Date | Author | Description ! ! |----------|------------|--------|-------------------------------------------------------------! ! | 1.0 | 2022/03/07 | H.P. | Document Creation ! !--------------------------------------------------------------------------------------------------! ! Create an alias for the string datatype for task types, Normal, Static, SemiStatic ALIAS string tasktype; ! Create a record for storing data about all tasks in the system RECORD fe_taskdata string Name; ! Task name from the Controller System Config tasktype Type; ! The type of task in case this is relevant for certain operations tsp_status Status; ! Task active in controller status bool Executing; ! Task executing in controller status ENDRECORD ! Constants representing each type of task CONST tasktype TKT_Normal := "NORMAL"; CONST tasktype TKT_Static := "STATIC"; CONST tasktype TKT_SemiStatic := "SEMISTATIC"; CONST tasktype TKT_None := ""; ! Store an array of the task types for easy searching VAR tasktype tkt_Types{4} := [TKT_Normal, TKT_SemiStatic, TKT_Static, TKT_None]; CONST num N_NumTaskTypes := 4; ! Number of different task types ! An array storing all task data PERS fe_taskdata tsd_Tasks{20} := [["T_ROB1","NORMAL",14,TRUE],["T_ROB1_GUI","NORMAL",14,TRUE],["T_ROB1_Maintenance","NORMAL",14,FALSE],["T_ROB1_Background","SEMISTATIC",14,TRUE],["tAwSys_1","STATIC",13,TRUE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE],["","",-1,FALSE]]; CONST num N_MaxTasks := 20; ! The maximum number of concurrent tasks !**********************************************************************************************! PROC LoadTasksFromConfig(INOUT fe_TaskData Tasks{*}) ! ! Description: ! ! Loads all task data into the given array ! ! ! ! Parameters: ! ! INOUT fe_taskData Tasks - An array, empty or otherwise of task data to be filled ! ! ! ! Author: Harry Parker Date: 2022/03/07 Revision: 1.0 ! !**********************************************************************************************! VAR num n_CfgIndex := 0; ! Index of the configuration attribute in the instance list VAR string s_TaskName := ""; ! Task name of searched task from the config file VAR num n_ListIndex := 1; ! The index of the input array to store the task data in VAR num n_TaskTypeIndex := 1; ! The index of the current task type to search for ! Loop through the array of stored tasks, while searching the config file for tasks WHILE n_ListIndex <= N_MaxTasks DO ! If there are still task types to search for IF n_TaskTypeIndex <= N_NumTaskTypes - 1 THEN ! Try and read the next name of a normal task from the config data ReadCfgData "/SYS/CAB_TASKS/Type/" + tkt_Types{n_TaskTypeIndex}, "Name", s_TaskName, \ListNo:=n_CfgIndex; ! If the end of the list has been reached IF n_CfgIndex = N_EndOfList THEN ! Have found all tasks of this type, search for the next type Incr n_TaskTypeIndex; ! Reset the search index to search from 0 for the next type n_CfgIndex := 0; ENDIF ENDIF ! Store the task name in the list Tasks{n_ListIndex}.Name := s_TaskName; ! Store the task type in the list Tasks{n_ListIndex}.Type := tkt_Types{n_TaskTypeIndex}; ! Update the task executing boolean & status for this task UpdateTaskData Tasks{n_ListIndex}; ! Increment the list index Incr n_ListIndex; ENDWHILE !----------------------------------------------------------------------------------------------! ERROR ! Error handler ! Check the error number for specific errors TEST ERRNO CASE ERR_CFG_NOTFND: ! Expected error for not finding configuration ! If there is no config data set the index to -1 and the returned string to empty n_CfgIndex := -1; s_TaskName := ""; ! Move to the next instruction TRYNEXT; DEFAULT: ! For other unexpected errors RAISE; ! Raise the error to the calling procedure or function ENDTEST ENDPROC !**********************************************************************************************! PROC UpdateTaskData(INOUT fe_TaskData TaskData) ! ! Description: ! ! Updates task data for the specific task ! ! ! ! Parameters: ! ! INOUT fe_taskData TaskData - Task data to have the status updated ! ! ! ! Author: Harry Parker Date: 2022/03/07 Revision: 1.0 ! !**********************************************************************************************! ! Update the execution status of the task TaskData.Executing := TaskIsExecuting(TaskData.Name); ! Update the active status of the task TaskData.Status := GetTSPStatus(TaskData.Name); !----------------------------------------------------------------------------------------------! ERROR ! Error handler ! Check the error number for specific errors TEST ERRNO CASE ERR_TASKNAME: ! Expected error for not finding the given task ! Return empty data for the executing and status parameters if no task is found TaskData.Executing := FALSE; TaskData.Status := -1; RETURN; DEFAULT: ! For other unexpected errors RAISE; ! Raise the error to the calling procedure or function ENDTEST ENDPROC ENDMODULE
I did unfortunately not find a simpler way than reading the system parameters, and in the end I didn't need the functionality. But I can see you created a really elegant solution.
Br//Markus Näslund0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
