SingArea\LockAxis4: Very weird behaviors
Can someone test this code on an IRB 4600-60/2.05 with RW 6.13.01.00:
MODULE Module1
TASK PERS tooldata tGripper_LS:=[TRUE,[[-162.201,7.50024,492.289],[0.653041,-0.653041,-0.271179,-0.271178]],[1,[0,0,1],[1,0,0,0],0,0,0]];
TASK PERS wobjdata wLTrfRWay_LS:=[FALSE,TRUE,"",[[1329.56,-494.855,690],[1,0,0,1.78363E-8]],[[420.69,-24.75,-40],[1,0,0,0]]];
CONST robtarget pEntryLTrfRWay_LS:=[[-600,-250,200],[0.707106781,0,0,0.707106781],[-1,0,-1,0],[9E+9,9E+9,9E+9,9E+9,9E+9,9E+9]];
PROC main()
!Add your code here
MoveAbsJ [[-9.56,-50,20,0,30,90],[9E9,9E9,9E9,9E9,9E9,9E9]]\NoEOffs,v1000,z50,tGripper_LS\WObj:=wobj0;
SingArea\Off;
MoveL pEntryLTrfRWay_LS,v1000,z50,tGripper_LS\WObj:=wLTrfRWay_LS;
SingArea\LockAxis4;
SingArea\Wrist;
ENDMODULE
PROC main()
!Add your code here
SingArea\Off;
SingArea\LockAxis4;
SingArea\Wrist;
ENDMODULE
SingArea\Off;
Works fine
SingArea\Wrist; Works fine, but tool orientation is not kept (I need it)
SingArea\LockAxis4;
The robot move strangely to, in final, trig an error...
SingArea\LockAxis4;
The thing is that All my position are calculated and in some case, I need this SingArea\LockAxis4.
Post edited by DenisFR on
Denis, the first thing that I notice is the lack of fine points in the moves. I suggest to try again with fine points.Lee Justice0
Yes, but I am thinking that it may be reading ahead, not having the actual setting at the time you think it is.Lee Justice0
BTW, good to see you back here Denis.Lee Justice0
Even If I Run it Step By Step, robot move really weird...0
Hi Denis. I built a station with that robot model and RW, tried your code. Is see the peculiarity that you mention, and it errors with axis 5 at joint limits. The tcp trace did not show for that move, but I suspect that, with axis 4 locked, that the robot is trying to force axis 5 through the wrist to remain on the path with the correct orientation. Another strange behavior that I saw was that when I changed that motion to joint, the robot locked axis 4 and also moved strangely until it faulted out. SingArea is for linear and circular interpolation, not joint.
Finally, from the manual is this: If the argument \LockAxis4 is specified, then axis 4 is locked to 0 or ±180 degrees to avoid singular points. The TCP will in general follow the correct path, but the orientation of the tool will deviate if the position was not programmed with axis 4 at 0 or ±180 degrees. For paths with large reorientations, the TCP may deviate from the programmed linear path.Lee Justice0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
