[Request] Place—> Two Frames improvement
Newman
It would be nice in addition to ”Place->Two frames”, to have a version where you select From= a body/part/group, To=another body/part/group.
Example use case can be as follows:
I want to test if the new layout/gripper version is working for loading a part in a fixture.
Design engineer exports CAD files:
1. A robot gripper including the part in the gripper.
2. A fixture including the part as it should be placed.
I attach the gripper to the robot and teach a target anywhere. Now I select this target->place->”two parts” and then selects from=part in gripper and to=part in fixure.
This will move the robtarget so that robot is positioned in loading position.
Maybe there already is a way to do this?
Currently I create frames and use Place-> ”two frames” but it’s kind of cumbersome when you testing layouts/gripper designs back and forth, with many fixture positions and many parts in robot grippers.
/David
/David
David
Swedish freelance ABB robot programmer
David
Hello,I'm not sure it's what you want but, you can define your part as UCS then set positions to 0.0
Yes
DenisFR said:Yes
I just want a quick way to put the robot in the load position, without creating any tcp's or temporary frames.
David
You can change part origin.Generally, I ask designer to represent gripper to position, so I only need to move tool0 to gripper origin.1
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
