Images in forum posts
Newman
Has something changed on this forum regarding attaching images in forum posts?
David
Swedish freelance ABB robot programmer
David
What do you mean?—Maxim RiabichevPC Software Support Engineer0
I can see that when I click on the image button, it only pops up a box which says, "image url". I cannot seem to browse or insert attachment.Lee Justice0
I see.
It should still be possible to upload an image to imgur.com (or equivalent) and link it to the post here.—Maxim RiabichevPC Software Support Engineer0 -
But as I remember you could paste images directly into your post before?
And instead of just url link you could browse an image from your local harddrive.
/David-----------------
David
I would also like to be able to select images for forum posts directly from my hard drive
/Daniel0 -
It is true that this was possible before.
A decision was made to disable that feature so that it would be impossible to share files, and potentially harmful files, on this platform.—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
