RobotStudio event
IRC5 Controller folders not visible in Filezilla
Hello everybody,
I have to write files on a IRC5 contoller with Filezilla.
I can connect to the controller, but the folders are not visible.
I receive the answer : 550 Permission denied
Is there some parameter which where I can set the access rights to FTP ?
Any idea ?
Thank you
Regards
Cornet Raymond
Manager
LUXROBOTIC programming Sàrl
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
PC HP ZBook 17 G3
intel Core i7 6700HQ 2.59 GHz
RAM 16GB
HDD 1TB
NVIDIA Quadro M1000M
  • In the link below there is a portion that deals with IRC5s and FileZilla Server.
    https://forums.robotstudio.com/discussion/11005/how-to-connect-to-abb-irc5-via-ftp-and-upload-prog-mod
  • Luxrobotic
    Luxrobotic ✭✭
    edited September 2022
    Hi SomeTekk,
    my goal is not to download program or modules from the PC to the robot with Rapid instructions.
    I just want to connect with Filezilla and download a data module from my PC to the controller, and afterwhile to be able to Load this data module from the HOME folder with Rapid instructions.
    I can do it with the File transfer from RS, but finally my customer will have to downlaod some data to the controller without RS Licence.
    In the normal times wityh other robots, I don't have such issue to have acce to the robot's folders via Filezilla.
    PS : I've tried without any firewall or antivirus.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • The IP address in your image seems to show you are using the Service/Management port. Perhaps FTP activities are NOT permitted (external to RS) through that port without the ftp option?
  • Luxrobotic
    Luxrobotic ✭✭
    Hi everybody,
    I've tested the FTP connection on an other robot, wich hasn't the FTP 614-1 option.
    I didn't have any issue to connect with the same settings (IP address : 192.168.125.1, User : ABB, Pwd : 007), I could also transfer files in the 2 ways.
    I had total acces to all the folders and files.
    It seems it's linked to the robot settings !
    :s
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Luxrobotic
    Luxrobotic ✭✭
    Hello everybody,
    I've checked the UAS of my robot, I thought it could be the reason, but all the grants are activated.
    Any idea ?
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • From the RS Operating manual:
    All the controllers have a preset group and preset user named Default Group and Default User respectively. The Default User has an open password robotics.
  • Hi,
    I tried with the PWD robotics. It's still Nok
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Hi everybody,
    I'm still stuck on the topic !
    Is there any solution ??
    As I told before, I succeed with several robots, but I only have the issue with one.
    (I can send both backups).
    Help please
    Thank you
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
  • Have you tried downloading a backup from a working system into the control causing problems? Additionally, have you tried an I-Start on, or built a new system then cold started, the control with the issue?
  • I can do it with the File transfer from RS, but finally my customer will have to downlaod some data to the controller without RS Licence.
    You should (and your customer) be able to FTP or just load a module even with an unlicensed version of RS.
    Lee Justice
  • Hi everybody,
    I finally succeed to connect with my PC or the customer's production PC using Filezilla and other FTP Client (WS_FT) with the following setting :
    IPv4 Config of my PC in DHCP.
    On the controller, I use the service port 192.168.125.1 (with User : Default User et PWD : robotics)
    I can put my Rapid module on the roobt's Home folder with a VBA macro.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
    PC HP ZBook 17 G3
    RAM 16GB
    HDD 1TB
