Where is the VC backup located when using Autosave in RS 2022?
Newman
I have RobotStudio 2022.2.1 and had a system failure on my VC.
My only hope to recover some background task is the Autosave fuction but I can't find any backup files in my project folders.
In options->AutoSave it looks like VC backup is enabled.
/David
/David
David
Swedish freelance ABB robot programmer
David
Hello Newman,
So I did some digging and these are my findings (in RobotStudio 2022.3):- RAPID code is backed up to "%localappdata%\Temp\RobotStudio\"
It only saves the un-applied changes made in the editor. As soon as you hit Apply, the "backup" is removed.
- The autosave of the station and station files does not work. (It looks like it does, but it doesn't.)
- Automatic backup of controllers does not work.
- If you manually save the project, a backup of the controller is made and placed in "...\RobotStudio\Projects\Project1\Controller Data"
I will speak to R&D regarding these issues with autosave.Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 - RAPID code is backed up to "%localappdata%\Temp\RobotStudio\"
Also when station is saved by me, I can see that RS is doing controller backup. But I can't find the backup in any folder.
Not in "...\RobotStudio\Backups"
Not in "...\RobotStudio\Projects\Project1\Virtual Controllers\BACKUP"
Does anyone know?-----------------
David
Seems like the controller backup stopped working when RS went from Solutions to Projects.
In an old RS solution I can find the controller backup in "...\RobotStudio\Solutions\Solution 1\Backups"-----------------
David
Thanks! I found the backups from save project in the "Controller Data" folder as you said.
Let's hope that autosave will be fixed too.
/David-----------------
David
David, are you saying that the backups of VC's work? Do you have multiple version of your VC in Controller Data?—Maxim RiabichevPC Software Support Engineer0
No, only one backups folder per robot controller.
I have three robot controllers in my current project so therefore three folders.-----------------
David
Alright, thanks.—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
