Video Capture
I was curious, is there any way to capture video of a simulation in robot studio 5.08?
dh_custompak2010-05-30 04:29:21Comments
I use a software called Camtasia to record a simulation.Per Svensson
Consat Engineering0 -
Hi Dustin,
Video capture will be available in 5.09. I'm looking into creating an addin for 5.08, just wait an hour or so
Johannes Weiman
Thats awesome! Thanks guys for the help
Thanks Again,
dh_custompak2010-05-30 04:45:22Dustin0 -
Try this (instructions included):
2007-03-21_164233_VideoCapture.zip
This is pretty much the same code that will be included in 5.09, so any feedback is appreciated
regards,
Johannes
Johannes Weiman
Thank you so much for the support, I am extremely excited to try this out!
Thanks Again,
dh_custompak2010-05-30 04:45:33Dustin0 -
I love it, keep up the good work! The only thing I see, and you might not be able to control but the color is off in some parts of the video and its a little laggy. The only other thing is I noticed it doesnt want to work on my dual display so right now it seems like when I use it I have to turn off my dual display. But again I just want to thank you a lot I love this add-on and would reccomend it to everyone who uses Robot Studio!
Thanks Again,
dh_custompak2010-05-30 04:45:42Dustin0 -
Hi Dustin,
This update should fix the dual display issue:
2007-03-22_131931_VideoCapture.zip
I haven't found a way to increase the color fidelity. But you should disable gradient background in the graphics to get rid of the worst color banding.
regards,
Johannes
Johannes Weiman
Awesome, that takes care of the worst problem that I was having.
Thanks Again,
dh_custompak2010-05-30 04:45:12Dustin0 -
I have tried the add-in but the toolbar is grayd so i cant use it.
What do i do wrong
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Read the info in the text file, need to install Windows Media Encoder 9Per Svensson
Consat Engineering0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
