RobotStudio. Failed to install virtual controller.
Mikolaj
Hello everyone,
I have a problem with creating virtual controller in RobotStudio. Error message in attachment. I tried this with three RobotStudio versions (2021.2, 2022.2.1, 2022.3.1) and on two different computers. It doesn't metter if I try with new system or with buckup - the problem is the same. I've made complete installation of RobotStudio few times. I've tried this solution: https://forums.robotstudio.com/discussion/9823/solution-failed-to-install-virtual-controller-rs6 but with no effects.
Any help would be great. Thank You in advance.
https://www.robot-forum.com/attachment/36383-abb-virtual-controller-error-png/
Post edited by Mikolaj on
Hi I can’t see any attachment.Systemintegrator - Web / C# / Rapid / Robotstudio
If I helped, please press Vote Up0 -
Hi,I forgot to add, sorry. I updated question and here also is link for this error:
Hello there,
Please uninstall any version of Iron Python from your PC and install version 2.7.4
https://github.com/IronLanguages/main/releases/tag/ipy-2.7.4
Please let me know if this resolved your problem.—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 283 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
