Is there a way to deact the E-stops from the flexpendant like in kuka robots?
in IRC5
Hi Alejandro
There are no built in methods that I am aware of.
On another note why would you need to? It could be dangerous if someone wants to E-Stop the machine and reaches for that stop button only to find out it doesn't work.
I imagine that disabling an E-Stop also voids any relevant warranties on the equipment too.
The only way I can think of if you really need to would be to modify the internal wiring although again this would void warranties and I don't think you'll find anyone on this site recommending it.
Perhaps just covering it up somehow with a hard case would work best so it can't be seen and no one tries to use it.
Good Luck,
Harry0
thank you i´ll try something different0
- 5.4K RobotStudio
- 384 UpFeed
- 15 Tutorials
- 12 RobotApps
- 290 PowerPacs
- 405 RobotStudio S4
- 241 ScreenMaker
- 2.7K Robot Controller
- 282 IRC5
- 44 OmniCore
- 3 RobotStudio AR Viewer
- 746 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
