what's the "TCP check"?
Hello avboy,
the TCP is the "Tool Center Point" and the "TCP check" is a routine to check the correct position of your tool. The routine moves the tool (weld torch for instance) to a fix point into your cell (a check pin) and so you can check the TCP. These fix point is always on the same position. When the TCP of the tool isn't correct, then you have to teach the tool again with the 4- point method, for example. Was the teach ok, then the TCP will be also ok and the seams should be at the right positions.
wow,so quick a reply! thank you
I finally know why there is a steel pin on delivery with the abb robot.
avboy2008-8-7 13:31:200 -
how can i check the TCP that i created in robot thought robotsudio
Hello,In RS, you can sync from RAPID to Station.0
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
