50263: Duty factor warning Error
Options
A robot that works in a pressline(as destaker robot) gives this arror a few times in a month. I wonder if it is a serious problem or only a warning.
Thanks for help in advance.
The duty factor for gear box at %s is too high. Check:
Reduce the speed or increase the wait time.
HnmN
Robot thinks it is being overworked on an axis. Depending on the robot, if you cannot slow down it's motion, there are optional fans that can be added to robot axis' 1-3. These fans help the robot run cooler and help eliminate the error.
THANKS FOR UR ADVISE.
HnmN0 -
For what axis do the robot gives "50263: Duty factor warning". One of the solutions is Slowing down its motion. I think the other one is modifying trajectories. The system warns you the axis is moving too much. I think you can better the trajectories.
Only God Can Judge Me0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 738 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
