Position validation
Options
I have a need to calculate potential positions offline and then validate them once I get online.
What is the best way to check if a given Cartesian position is reachable once connected to a live robot?
zev
Hi,I have made following RAPID function for thatFUNC bool IsReachable(robtarget pReach, PERS tooldata ToolReach, PERS wobjdata WobjReach)
VAR bool bReachable;
VAR jointtarget jntReach;
bReachable := TRUE;
jntReach := CalcJointT(pReach, ToolReachWobj:=WobjReach);
RETURN bReachable;
ERROR
IF ERRNO = ERR_ROBLIMIT THEN
bReachable := FALSE;
TRYNEXT;
ENDIF
ENDFUNCRegards,Mika0 -
Thank you for the code.
zev0 -
hey,I am trying to use the similar codebut my program goes to the error routine but it does return to the end of the procedure,but i have specified TRYNEXT;Any suggestions0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 280 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
