Record to viewer function not active
alokpdd
Can someone help in rectifying this problem:-
Like you see in the picture attached, the "Record to viewer function" is not getting highlighted. Also the pause function in simulation is inactive. Pls suggest.
alok
To activate these functions you need to use virtual time mode "Time Slice" and not "Free Run". You can configure this in the RobotStudio options.Henrik Berlin
ABB0
- 858 RAPID Programming
