SmartComponent: Pick & Place simplified
Pavel Riabichev
edited February 2017 in RobotStudio
Hi all!
Try my new SmartComponent "PickAndPlace" which enables you to quickly and simply set up a Pick & place simulation.
Description:
This component is a combination of Attacher, detacher, collision sensor and timer combined with codeBehind. The picked object will be attached as it collides with the tool and dropped as it collides with the "Object to drop on." If the checkbox "Use IO for Pick/drop" is used, the collision sensing will be disabled so the picked object will only be attached/detached when using the Pick/Drop input. It is possible to set groups containing multiple objects as "Object to drop on" and "Object to pick."
Properties:
Tool (ProjectObject) - Attachment parent
Object to pick (IAttachableChild) - Object to attach
Object to drop on (IAttachableChild) - Attached object will be detached as it gets in contact with this object
Pick/Place blocked duration (Double) - Re-attach will be blocked for this duration after placing an object, this gives time to move away from contact
Mount (Boolean) - Moves the object(local origin) to the attachment parent or TCP if it exists
Flange (Int32) - Mechanism flange or TCP to attach to
Offset (Vector3) - Position relative to the attachment parent
Orientation (Vector3) - Orientation relative to the attachment parent
Attached part (Part) - The part currently carried
Dropped on part (Part) - The part on which the carried object will be dropped
Use IO for Pick/Drop (Boolean) - If checked, the component will stop sensing for collision and will instead only attach/detach when signal Pick/Drop is used
Inputs:
Active (Digital) - Set to high (1) to activate the component
Pick/Drop (Digital) - Will attach/detach object as this signal is set/reset
Outputs:
Executed attach (Digital) - Pulses high(1) when object is attached
Executed detach (Digital) - Pulses high(1) when object is detached
If you have any suggestions for improvements or found any bugs, you may report them in this thread.
(16-12-01) uploaded a new version PickAndPlace_v2 which has some new features.
It is now possible to select a component group as "Object to pick." The tool will then pick up the first child it senses within that group.
Added 2 properties: 'Attached part' and 'Dropped on part'. These make it easier to attach the object to something that it was dropped on.
(17-02-16) uploaded a new version PickAndPlace_v3
Fixed a bug that caused an error in the start of the simulation.
/Pavel
Post edited by Pavel Riabichev on
