Making certain graphical parts non selectable
I have a need to make some graphical parts non selectable in stations.
This then avoids the accidental left click graphical selection and maybe protection on important parts in a station.
I appreciate that you can change selection levels to avoid part selection, but this is for all parts in the station, but I still require part selection only on certain parts
Currently I achieve this by using two identical parts in the same place and a smart component graphical with two switches to show alternate visibilities.
It would be great if there was a standard option so protected parts could only be selected by maybe an initial right click or only selectable from the browser!
Kind regards
Best Answer
Hello,You have this when item selected in Component Group Tools - Modify - Selectable in 3D View7
You are right!
This is not seen in the context menu so I guess that's why I missed it!
many thanks
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
