Comparing posititions
Options
Hi there
I am working on a project and need to compare two positions, but can't figure out how to do it.
Thanks in advance!
Thanks in advance!
It looks like it might work. Single step forward one line at a time so you can see the values and the evaluation of the expressions.Lee Justice0
lemster68 said:It looks like it might work. Single step forward one line at a time so you can see the values and the evaluation of the expressions.
Well, if even one number is mismatched five decimal places over I suppose it will evaluate to NOT TRUE. Try instead the Dist() function and use a value that is very small, like 0.5mm.Lee Justice0
lemster68 said:Well, if even one number is mismatched five decimal places over I suppose it will evaluate to NOT TRUE. Try instead the Dist() function and use a value that is very small, like 0.5mm.
Is it Instruction - Mathematics - Distance?0 -
It worked! Thank you!0
Hello,Be careful, Distance only give you the distance. It doesn't take care of orientation neither configuration.0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
