Load a shared RAPID module using RWS
Options
mkatliar
Dear colleagues,
With RWS one can load a RAPID module into a specified task: https://developercenter.robotstudio.com/api/rwsApi/rapid_task_loadmod_page.html
There are, however, shared modules, which do not belong to a specific task but are shared between all tasks. How can I load a shared module with RWS?
You must enable/select the option "Shared" inside the Configuration - Automatic Loading of Modules - then on the respective Module. See attached.
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
