How to visualize RAPID variables of a virtual controller in robotstudio
Options
I have a controller configured in IoT Gateway. It seems all is correct. From an OPC client I can display the tree with the Objects, types and views, but I do not display any RAPID variables. Can someone help me ?
Note : Is a virtual controller from RobotStudio0
You can only view "Pers" variables. Do you have any of those?—Maxim RiabichevPC Software Support Engineer0
Yes, I have PERS variables.
On the other hand, if I install OPC DA I can see everything
Regards0 -
Make sure you have to correct RobotWare options. You can check in the manual which ones are required for respective RobotWare.—Maxim RiabichevPC Software Support Engineer0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
