Geometry import from inventor .iam does not work correctly
Options
kuv_vokl
this is a very old problem, but now i try to get any help or information about this issue.
if you try import an .iam file with contains parts/components NOT in the .iam folder, then can not import this parts/components, because the "iProperties" from this part/component would NOT be used for the right location for this file.
Does anybody know what is to do ?
If this is a bug, please make un update asap.
Thx
Klaus
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 738 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
