Error when creating Omnicore projekt with "customize options"
Options
Gpe
If I create the system without "customize options" it starts, but the function modify options in the controller tab doesnt work.
Have anyone experienced this behaviour ?
tried to reinstall both windows and RS without change.
Running RS 2023.4.1 and Windows 10 pro
Error code below.
RobotStudio .NET exception: Method 'DisposeAsync' in type 'Microsoft.Extensions.DependencyInjection.ServiceProvider' from assembly 'Microsoft.Extensions.DependencyInjection, Version=6.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' does not have an implementation.
============================================Base exception: TypeLoadException
at RobotStudio.UI.InstallationEditor.InstallationEditorWindow..ctor()
at RobotStudio.UI.InstallationEditor.InstallationEditorCommandHandler.<LaunchWindow>d__6.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.UI.Controller.TemplatesVm.<CreateController>d__45.MoveNext()
at RobotStudio.UI.Controller.CreateVcCtrl.<CreateController>d__38.MoveNext()
I am experiencing the same issue. I also can't Change Options in any of my OmniCore virtual controllers anymore. I have reached out to ABB Tech Support for some assistance. I'll post a solution if I have any success. Running Robot Studio 2024.1.10
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 280 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
