IRC5 XS0 power connection
I have an IRC5 M2004 controller and it came without a power cord. I need to make one but the XS0 main 240V power connection is proprietary to ABB and I can not for the life of me find a part number. Can someone please point me towards one?
I would recommend looking at the following part number from Harting. I believe this is what you are referring to.
Harting, 19 20 003 1640
Harting, 09 12 005 2733
Harting, 19 00 000 5184
Fair warning. These are a PIA to wire unless you have exactly the right wire with the recommended insulation thickness.
Thank you! This is exactly what I needed. My connection is 3 pin. Will it work with this 5 pin connector?
Yes it will. ABB is using a 5 pin connector and only wires up 3 of the pins. L1, L2 and PE. The information on this plug can be found in the manual 3HAC047138-001.
1 -
Thank you!0
- 5.5K RobotStudio
- 390 UpFeed
- 17 Tutorials
- 13 RobotApps
- 296 PowerPacs
- 404 RobotStudio S4
- 245 ScreenMaker
- 2.7K Robot Controller
- 302 IRC5
- 55 OmniCore
- 3 RobotStudio AR Viewer
- 764 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 4 Job listings
