Simulation speed is low and RS in not using much processor or memory
Ulkaj
I have problems with simulation speed in RS 2024, i have a station with one IRB and one CRB15000. When I run a simulation the speed is between x0.7 - x2.0.
Earlier versions of RS (2022 or 2023) I had speeds up to x5.
I have RS set simulation speed to "as fast as possible"
Some of my simulations takes up to 4-5hours to run at this low speeds.
My CPU is a HP ZBook
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz 2.30 GHz
32,0 GB
nVidia RTX A2000 GPU.
I have tried to change settings to let RS use max performance. But nothing seems to make the simulations run faster. RS only uses a couple of % of Memory and CPU
32,0 GB
Have you: Right clicked on the RS icon. Select "Run with graphics processor". Select the high performance graphics rather than the onboard graphics.Lee Justice0
Which RS icon do you mean? I havent manage to click on any RS icon where i can select "Run with graphics processor".
In windows settings - system- graphics Robotstudio 2024 is set to high performance and the "NVIDIA RTX A2000 laptop GPU".
When i start RS this message comes up in the output window "Graphics device: 'NVIDIA RTX A2000 Laptop GPU', feature level D3D_FEATURE_LEVEL_11_0"0 -
The icon on the desktop.Lee Justice0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 345 IRC5
- 71 OmniCore
- 843 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
