Robot Base Frame Wrong
I'm trying to build a robot and external axis system on omnicore using an IRB 2600 and a custom-built external axis gantry.
The external axis wizard does not seem to work, I'm guessing that is because the external axis wizard was made for IRC5, not omnicore.
So instead, I followed the instructions from https://search.abb.com/library/Download.aspx?DocumentID=3HAC082287-001 telling me to load a template file from the robotware additional axis (M7_DM1.cfg) into the virtual controller parameters. Once I restart the VC, I configure the new axis to be my gantry, attach the robot to the gantry, reposition the robot, and say yes to the base frame being updated by the gantry.
From then on, every time I restart the controller, a message pops up telling me that the base frame definition is not the same as in the virtual controller. But when I go to motion configuration the base frame of the virtual controller is set the same as in the station. When I try to create points in space, the station matches the points, but when I try to drive the robot along the path, the robot will drive to the wrong spot.
I have checked the MOC.cfg file and it shows that the robot base frame has been update to what the station is.
Does anyone know how to solve this? I want coordinated motion between the robot and external axis.
- 5.5K RobotStudio
- 396 UpFeed
- 18 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 319 IRC5
- 63 OmniCore
- 802 RAPID Programming
- 4 AppStudio
- 3 RobotStudio AR Viewer
- 18 Wizard Easy Programming
- 105 Collaborative Robots
