Popup dialog in AppStudio
Is there away to get popup dialogs in AppStudio? That was possible in AppMaker.
You can use the TComponents.Popup_A interface to implement a simple Popup component. If you're accustomed to coding with the FPComponent component, you can also directly use the FPComponents.Popup_A interface in AppStudio to write your code.
Here are some examples:
Danger:
try { // do something } catch (e) { TComponents.Popup_A.danger('Something went wrong', [e.message, e.description]); }
Error:
try { throw new Error("Whoops!"); } catch (e) { TComponents.Popup_A.error(e, 'Custom title'); };
Info:
TComponents.Popup_A.info( "Important information!", [ "For your information, this is a popup dialog.", "", "Further information can be given here!" ], function (action) { console.log("OK button was clicked") });0
- 40 AppStudio
