RS Programming Tab - Fails to Display
Options
Spider
Occasionally, when I select Programming Mode and double-click a module to display the rapid program, I get a grey field with no text.
When I hover the cursor around the 'empty' screen I get the declaration popup for whatever datatype or instruction information I happen to stop on.
When I move the cursor away, the popup remains and another popup displays the datatype or instruction information where I happened to stop.
The only way I've found to correct this behavior is to completelyshut down RS and Restart Windows XP.
I'd like a fast, more convenient, solution.. ..ideas?
M. McGraw
<font face="Verdana, Arial, Helvetica
- 5.4K RobotStudio
- 382 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 281 IRC5
- 48 OmniCore
- 3 RobotStudio AR Viewer
- 740 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
