Messaging domain problem, "string" != "string"
Options
Laro88
The error basically says that "string" != "string" - which makes me wonder what is going on
I just altered the code to use "num" as the datatype and it works when altering the datatype in the IRC5 code to num...
C# looks like this ( the commented s definition works )
string s = "string;"+ value; //value is of type string
//string s = "num;1"; //Tx of numbers works
msg.SetData(new System.Text.UTF8Encoding().GetBytes(s));
msg.UserDef = ID;
msg.Sender = ipcQueue_ToRAP.QueueId;
ipcQueue_ToRAP.Send(msg);
Laro882009-11-10 13:20:560 -
Problem solved, misleading error message
Strings must be wrapped in " so the string to be send should look like this:string s = "string;""+ value+""";
The string != string error is misleading, it should say something like
"illegal string wrapping or termination"
Can't understand how to send strings via RMQ messaging. I can send only like this, but I need to send different strings:
Byte[] data = new UTF8Encoding().GetBytes("string;\"hello world\"");Laro88 said:Problem solved, misleading error message
Hello,You don't escape well ".You're near on comments:Byte[] data = new UTF8Encoding().GetBytes("string;\"" + strMsg + "\"");This create a string = (string;"Your Message").1
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
